Wanting Outlook express back
juliasdream
I was quite happy and used to using Outlook Express
My new computer has Vista which incorporates Windows Live Mail. I really don't like it and I can't find a way to uninstall it.
It wont let me install Outlook Express because of Live Mail being there
Does anyone have a solution?
8 REPLIES 8
shutter
Fixes: 65
Re: Wanting Outlook express back
Use Firefox, and Thunderbird, as an alternative.....
mal0z
I did a mini survey to see what was the most popular email program here and Thunderbird was clearly in the lead.
I've used it for several years and can recommend it too.
http://community.plus.net/forum/index.php/topic,78330.0.html/
get it here:
http://www.mozillamessaging.com/en-US/thunderbird/
How to set it up on plusnet
http://www.plus.net/support/email/setup/thunderbird_video.shtml
http://www.plus.net/support/email/setup/thunderbird.shtml
James
Wouldn't a Support Library article be helpful.
[me=Jameseh]whistles away[/me]
juliasdream
I knew about thunderbird but I thought I'd look for what else is on offer.
I guess there were things I preferred about OE mainly because I'm used to it
I think from the look of it Live Mail is just a bad cloning of Thunderbird. Its rubbish
I think I'll go with thunderbird and try to get used to it
James
I've starting writing a guide on setting up Thunderbird in the Support Library.
It's really straightforward but give us a shout if you get stuck.
juliasdream
Thanks to all who tried to help.
In the end I downloaded Opera 10 to give it a try.
It works a treat.
I like it better than thunderbird but I'm not giving up Firefox
decomplexity
Hmm... Vista incorporates Windows Mail, not Windows Live Mail (WLM, formerly Windows LIve Mail Desktop) .
You would not have WLM unless you had installed it (free).
WLM is (broadly) Outlook Express with a new front-end and built in facilites to synch local calendar and contacts with Windows Live (central) ones which are also used by Hotmail. You can also synch your Inbox etc with Hotmail maiboxes.
Zen from May 17. PN Business account from 2004 - 2017
HPsauce
WLM also gets around all those odd restrictions on POP access to Hotmail accounts.
Been using it for quite a long while now, alongside Outlook; it has it's place and isn't that bad really.
