WYSIWYG
mort7890
Fixes: 4
WYSIWYG
I am wondering if anyone can help setting up a hit counter for each page on a web site designed in WYSIWYG. I have searched plusnet and not found anything recently. Plusnet used to have a counter but closed it down and since then I have never found a reasonably easy (senior easy) to understand and would appreciate an easy solution. Many thanks in advance.
4 REPLIES 4
Pete11
Seasoned Pro
Fixes: 4
Re: WYSIWYG
@mort7890
http://www.reliablecounter.com/
Take your pick, loads of options. Thumbs_Up
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
shutter
Fixes: 64
Re: WYSIWYG
@mort7890  you could use Google Blog ,... it has it`s own "stats" that you can view anytime... and you don`t have to pay for web hosting... as it is FREE  !..
https://www.blogger.com/about/?r=1-null_user
mort7890
Fixes: 4
Re: WYSIWYG
http://www.reliablecounter.com/ looks reasonable so will give it a try, many thanks for the help and guidance.
mort7890
Fixes: 4
Re: WYSIWYG
Tried but did not work as it appears that WYSIWYG uses php and PN do not use that, I think, so further help required please.
