WIFI in Garden Cabin
niknaknoo73
I have a shipping container office in my back garden. Once the door is closed I am not able to get any WIFI signal in there.
Is there anything I can do to get WIFI in there?
Sorry if this is a really silly question that has a simple answer.
Thank in advance
3 REPLIES 3
RichardB
Seasoned Champion
Fixes: 39
Re: WIFI in Garden Cabin
Hi
The metal shipping container is a very goid Faraday cage. It will block all radio signals including WiFi.
I would recommend running outdoor grade ethernet cable to the shipping container and using a WiFi access point inside the container.
I have an old Plusnet router as an access point in the summer house fed by outdoor grade ethernet cable.
Regards
Richard
Fixes: 250
If you have power in the container, consider Ethernet over Power adapters - see Devolo products.
Fixes: 1,495
Moderators Note
This topic has been moved from ADSL Broadband to Tech Help
