WIA Scanner
morgan2476
WIA Scanner
Hi folks
I have windows 7 and my scanner software will not work with it.  Does anyone know where i could get a hold of WIA software?
Fixes: 62
Re: WIA Scanner
which scanner
morgan2476
Re: WIA Scanner
It is a mustek bearpaw 2448ta pro.  This is the second time I have installed win7, the first time I managed to get the scanner to work in a basic mode - I think it was a WIA application.
Fixes: 62
Re: WIA Scanner
I assume you have tried this one
http://www.downloadatoz.com/driver/item_205277.html
morgan2476
Re: WIA Scanner
I will give it a go. Thanks.
Mustek say they are not going to do a driver for this scanner.  It did work before but I cannot remember how I got it to work.
Fixes: 24
Re: WIA Scanner
Quote from: morgan2476
If you installed Windows 7 over your old Windows 7 then there may be a Windows.old folder with your old files in it so the drivers file you used previously may be there.  Or perhaps you made a backup of your old files?  Adiewoo seems to think you are too careless to have done that but I wonder if you are just not thinking through how to retrace the steps of what you did previously?
Fixes: 247
Re: WIA Scanner
Obviously not as they are here asking for help, so not sure of the point of your post exactly?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 20
Re: WIA Scanner
This was one of the issues that made me drop M$ s/w, my printer & scanner weren't supported in Vista and wouldn't be, I wasn't about to splash out for new kit when the stuff was working fine. And still is  Cheesy
If it worked before I would do a google for "Win7 mustec bearpaw 2448ta pro driver" or similar
pierre_pierre
Re: WIA Scanner
and there are a few
Technical data - Mustek Bearpaw 2448CU Pro II - Scanner
Avast pro antivirus license key · Bearpaw 2448cu pro ii driver download · Bearpaw 4800ta pro ii driver · Cool edit pro free download full version · Driver ...
en.kioskea.net/.../1062030-mustek-bearpaw-2448cu-pro-ii - Cached - Similar
Show more results from en.kioskea.net
Mustek BearPaw 2448 TA PRO driver download Scaner for windows free ...
Windows 7 continues grow far faster than its predecessor Windows Vista, ... Files drivers for Mustek BearPaw 2448 TA PRO are temporary unavailable. ...
<snip>
Download Mustek BearPaw 2448TA Plus/Pro Vista Driver v.1.0 ...
22 Mar 2008 ... Mustek BearPaw 2448TA Plus/Pro Vista Driver v.1.0. X-DRIVERS. ... Operating systems. Windows 7 64-bit/Server 2008 R2 KB978251 ...
www.x-drivers.com/.../drivers/.../bearpaw_2448ta_pro/7744.html - United States - Cached - Similar
