WEBWISE again
- Re: WEBWISE again
WEBWISE again
27-11-2008 5:04 PM
BT have assured +Net this would never happen again, after their last incursion
Note URL where BTWEBWISE seems to have taken over the routing to adobe.com
I had clicked on my Adobe programmes help button, which takes you to their www;
URL that came up, as not clear on image: clearly shows the hijacking
http://webwise.bt.com/consumer/invitation.php?orig-url=http://www.adobe.com/support/techdocs/330714.html&request-id=2A7BAFAC&srv=a.webwise.net
All 2 lines above were the URL, not the hypalink this post creates.
Re: WEBWISE again
27-11-2008 5:06 PM
Was it you that this happened to last time?
I'm going to have someone look into this asap.
Re: WEBWISE again
27-11-2008 5:08 PM
Re: WEBWISE again
27-11-2008 5:40 PM
Also see https://nodpi.org/forum/index.php/topic,449.0.html - I've posted again to the end of the topic.
Re: WEBWISE again
27-11-2008 5:53 PM
BT are my phone provider incidentally, if that's pertinent?
Re: WEBWISE again
27-11-2008 6:13 PM
is not such a good routing[flash=200,200]http://community.plus.net/forum/index.php?[/flash]
Re: WEBWISE again
27-11-2008 6:15 PM
Re: WEBWISE again
27-11-2008 6:18 PM
This is what my RIN tracert looks like:
C:\Documents and Settings\John>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.251.195]
over a maximum of 30 hops:
1 3 ms <1 ms <1 ms dg834 [192.168.0.1]
2 21 ms 19 ms 14 ms 217.47.89.122
3 9 ms 9 ms 9 ms 217.47.89.161
4 21 ms 17 ms 16 ms 217.47.88.10
5 15 ms 15 ms 30 ms 217.41.171.21
6 11 ms 11 ms 9 ms 217.41.171.65
7 11 ms 9 ms 9 ms 217.41.171.122
8 22 ms 22 ms 19 ms 217.41.171.50
9 32 ms 31 ms 28 ms 217.47.88.114
10 12 ms 10 ms 10 ms core1-pos6-1.kingston.ukcore.bt.net [62.6.40.74]
11 13 ms 10 ms 11 ms core1-pos0-0-0-8.ealing.ukcore.bt.net [62.6.201.69]
12 13 ms 10 ms 10 ms core1-pos1-0-0.telehouse.ukcore.bt.net [62.6.201.82]
13 11 ms 16 ms 17 ms 194.74.65.42
14 11 ms 11 ms 10 ms 212.58.238.129
15 12 ms 11 ms 11 ms 212.58.239.58
16 * * * Request timed out.
17 * * * Request timed out.
(Incidentally, if you right click the icon in the top left hand corner of the Cmd window you can mark the text and then copy it)
Re: WEBWISE again
27-11-2008 6:23 PM
I assume it performed worse than the RIN did judging by data generated.
Moderator can see altered IP addresses.
Re: WEBWISE again
27-11-2008 6:30 PM
Your traceroute looked okay
I think the timeouts are just caused by a webserver which rejects ICMP traffic.
Re: WEBWISE again
27-11-2008 6:31 PM
Re: WEBWISE again
27-11-2008 6:31 PM
Re: WEBWISE again
27-11-2008 6:36 PM
The number of hops a a BT connection always appears more because on RIN the connection is not tunnelled through to a Gateway - all the IP addresses along the way are shown. On the Plusnet connection we will be going through many of the same boxes, it's just that because it's tunnelled the hops are invisible.
Re: WEBWISE again
27-11-2008 7:12 PM
Quote from: jelv The number of hops a a BT connection always appears more because on RIN the connection is not tunnelled through to a Gateway - all the IP addresses along the way are shown. On the Plusnet connection we will be going through many of the same boxes, it's just that because it's tunnelled the hops are invisible.
Actually that is not correct. RIN is tunneled through to a gateway (slightly closer to the edge) and there is only 1 extra 'hop' hidden by the tunnels to PN. The reality is hop count is largely irrelevant anyway assuming both networks are uncontended as the routers along the way do not really add latency. Of course the fewer hops the less that can go wrong along the way.
I'm surprised that you find streaming worse on the PN network as it's in the Gold queue which right now has no latency and no packet drops.
Phil
Re: WEBWISE again
28-11-2008 10:08 PM
http://groups.google.com/group/uk.telecom.broadband/browse_thread/thread/36075d581b1f1f9b?hl=en-GB#
