WD caviar drive knackered
- WD caviar drive knackered
- « Previous
- Next »
Re: WD caviar drive knackered
15-07-2015 6:46 AM
Quote from: nanotm if bios can format the drive chances are you can get it working under windows but its not a certainty
BIOS formats it EXT2. Windows doesn't recognise it. Always a bummer when that happens
[me=Waldo]extracts tongue from cheek[/me]
15-07-2015 7:30 AM
the bios format type is irrelevant because windows will see it as an operational unformatted drive and you can use disk manger in dos shell to sort that out if you cannot perform the required task through the computer management console.
the real problem is the high likelihood of it not working in this instance either way due to some part having failed /
- « Previous
- Next »
