WD MyBookLive Wireless Backup LAN with iMac Time Machine
Bobcat
Trying to reconfigure WD MyBookLive to back up from iMac Time Machine following ISP migration from Madasafish to Plusnet. Any help much appreciated since I am getting message about CNID DB access with offer to set up temp CNID DB or 'Read Only' Time Machine backups! Thanks folks.
Fixes: 24
Re: WD MyBookLive Wireless Backup LAN with iMac Time Machine
Since this is a Mac software problem, the Mac/Linux software forum might be a better place to pose this question.
Fixes: 182
welcome to the forums bobcat Smiley
have a look at this http://dthpham.com/post/21425883539/fixing-a-corrupted-netatalk-cnid-db
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
