Voyager 2110 password
Forest
I've been with plusnet for a while and have a Voyager 2110 router.  When I first got it, I disabled the wireless access on it as I only had a desktop and there was no need for it to be on.
I now have a laptop which I want to connect to the router wirelessly. It works fine with the ethernet cable. I presume I have to go to http://voyager.home and reenable wireless there but.... it keeps asking me for a username/password. I understood this to be the one Plusnet had sent me (username@plusdsl.net, and the password I use to log into Plusnet (eg to access webmail)) but the password box just keeps popping back up again.
So, is it a different password? Or is there another problem? And how can I get into the stupid thing! I've just spent Christmas sorting out my family's network so it's doubly annoying not to be able to fix my own...
Fixes: 62
Re: Voyager 2110 password
It is a different password - if you left it as the default it should be
Default login: "Admin". Password: "Admin" or "Password"
Forest
I don't remember changing it but I've tried the Admin/Admin/Password combos with no luck
Undecided
dick:quote
Fixes: 62
http://www.plus.net/support/hardware/voyager2110_setup_guide.pdf
This say that the login is user admin password admin note all lower case
There are other things in the pdf which may help
