Voyager 2110 not so secure?
- Re: Voyager 2110 not so secure?
21-09-2007 3:37 PM
I could change the IP but that can be tracked down and found so there's no point.
Anybody got any ideas?
Andy
21-09-2007 3:39 PM
What's the problem here? That your MAC blocking isn't working or that your router saves all your connection details?
21-09-2007 3:53 PM
21-09-2007 3:54 PM
Change the admin password, problem solved.
21-09-2007 3:57 PM
Quote from: Jameseh
I actually thought I had when I installed it but there it was in all it's glory my main login password and not the one I created.
21-09-2007 4:02 PM
BTW the 'manual' is pants.
Andy
21-09-2007 4:03 PM
EDIT: Incase what I said was confusing. I meant they can access the initial login prompt, but not get further without the username and password.
21-09-2007 4:05 PM
21-09-2007 4:08 PM
Quote from: MikeWhitehead .... you'll just need to set an alternative administrator username/password if you don't want them to access the configuration settings.
As I said, I thought I had, more importantly I don't want people accessing my login for things like the website and ccgi server etc. It was a little worrying. I'll give it another look later.
Andy
21-09-2007 7:15 PM
21-09-2007 7:23 PM
Quote from: God I think it's that we are used to Netgear... Where you see nothing unless you have a password. I was surprised to find that you could see the account name, but without the password you can't change anything.
So all the details are displayed to begin with, without a login required? Ouch, bad move to have these routers running like this hehe.
Oh and God, Linksys > Netgear
21-09-2007 10:14 PM
Note to self: Get off soap box and go to bed and sleep it off!
06-10-2007 6:20 PM
Another thing i found annoying about the 2110 v Netgear DG834PN was that if I used my external IP i got that damn fron page instead of my services grrr!
