Voip as intercom on plusnet hub one
- Voip as intercom on plusnet hub one
19-06-2017 7:11 PM - edited 19-06-2017 7:14 PM
Hi all, I need some pointers to set this up, I have a 'power over Ethernet' setup in the house, this includes the garden room at the bottom of my 200ft garden, I have two Voip phones i picked up cheaply and would like them linked on my hub to act as an intercom between the house and garden or visa-versa, is this possible, if so any pointers would be helpful to a nube. I have no plug and play driver disks or setup instructions for these.
thanks in advance
Frank Grimace
Re: Voip as intercom on plusnet hub one
19-06-2017 8:12 PM
Why be all "techy" about it.... why not buy a pair of PMR units... like this...
You could use them anywhere... i.e. missus in shopping mall... you in pub... .... these have a range of 3 km and would certainly be able to cope with a 200 ft garden !..
19-06-2017 8:19 PM
@Frank-Grimace what make and model are the phones ?
19-06-2017 8:43 PM
Hi they're 'Mitel 5304'
19-06-2017 9:32 PM
Normally you need to register VoIP phones with a sip server. You MIGHT be able to use the ' hot line' facility of those phones to specify the other phone"s IP address. Start by looking at the configuration guide here https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://edocs.mitel.com/UG/EN/5304_SIP7.2_UG_F...
I'm afraid it's not going to be simple though...
29-06-2017 11:50 PM - edited 30-06-2017 12:11 AM
VOIP phones like that need to be used with a "VOIP Phone Exchange" of some flavour.... so you won't be able to use them as a direct intercom.
However, you might be able to use them with a VOIP service..... take a look at www.sipgate.co.uk. Whilst they primarily offer a PSTN to VOIP "gateway", I believe that you CAN call voip to voip.
**Stop Press**
just found this:
https://docs.switzernet.com/people/emin-gabrielyan/070405-budge-tone-without-sip-server/
shows how to make a pair of (another make) voip phones call each other, you might be able to do the same with yours
