Vodafone Sure Signal on Plusnet
- Re: Vodafone Sure Signal on Plusnet
15-10-2010 2:53 PM
Regards,
03-11-2010 10:54 PM
Vodafone Sure Signal - is really a VOIP system - this means it should get a good priority over plusnets network, if it doesnt then this can easily be raised with the Networks team in the usual method (data capture of what is being transmitted by the device)
There should be almost no issues with the setting up the device itself, but id recommend putting it in a DMZ, to ensure the routers firewall does not interfere with the connection.
04-11-2010 8:29 AM
Quote Vodafone Sure Signal - is really a VOIP system - this means it should get a good priority over plusnets network
I believe its actually an IPSec VPN system. It creates a VPN tunnel to the Vodafone servers to carry the GSM traffic. Given that, it won't be seen by the PlusNet traffic management as VOIP, rather as IPSec which on some tariffs is restricted.
04-11-2010 9:23 AM
Quote from: MisterW I believe its actually an IPSec VPN system. It creates a VPN tunnel to the Vodafone servers to carry the GSM traffic. Given that, it won't be seen by the PlusNet traffic management as VOIP, rather as IPSec which on some tariffs is restricted.
Not to an extent where it's going to cause problems though. The traffic's still high priority, even if it is rate limited. We've a number of people here who use the devices at home and they don't have any problems. There's a couple in the office too. One is hooked up to a Thomson 585v8 whilst the other is using a 2Wire 1800HG.
07-12-2010 11:11 PM
Just came across your post whilst trying to setup my vodafone sure signal box with my TG585 v8 router. I have visited the vodafone troubleshooting (http://forum.vodafone.co.uk/t5/Vodafone-Sure-Signal/Sure-Signal-Light-1-On-Light-2-Flashing/td-p/495...) guide & the port forwarding (http://portforward.com/english/routers/port_forwarding/Thomson-Alcatel/TG585v8/Vodafone_Sure_Signal....) page for help and have setup a Game/Application forwarding ports 50,4500,500 & 123 and this is linked to a profile of my Sure Signal box which I have set to always assign the same IP. However I am still in the situation of having the @ light flashing on my sure signal. Any help on how your router is setup would be much appreciated.
Thanks!
Tim
16-12-2010 9:20 PM
I gather the main issues with getting them to work is more due to latency than speed.
17-12-2010 10:10 AM
Quote from: tbowker Any help on how your router is setup would be much appreciated.
Hi Tim,
We just plugged it in and it worked straight out of the box. Do you have any other port forwarding rules set up? I think the Sure Signal shares ports with certain Cisco VPN set-ups. You might also want to check that UPnP is switched on.
