VoIP question
greygit1
VoIP question
I use a VoIP connected phone number. I recently tried calling a number that was PSTN connected (but has been ceased).
I received an 'engaged' tone.
I also called the same number using a mobile phone and got a 'number unobtainable' tone.
I was assuming that a number which doesn't currently have a 'path' to it would get a 'number unobtainable' tone.
Could there be something misconfigured in the VoIP related equipment in my home/premises? Could there be something misconfigured in the VoIP related equipment in VoIP provider's network?
Did I mistakenly assume that a number which doesn't currently have a 'path' to it would get a 'number unobtainable' tone?
Anything else?
10 REPLIES 10
Fixes: 587
Re: VoIP question
Could be either your equipment or the voip suupliers. You would need to look at the received SIP response code ( using something like wireshark )
It's all defined here https://datatracker.ietf.org/doc/rfc3666/
greygit1
Re: VoIP question
My equipment came pre-configured by the VoIP supplier so I suppose I'll be talking to A&A.
Fixes: 587
Re: VoIP question
@greygit1 since you're with A & A you should be able to see the SIP response codes from the control panel.
Login to your control panel and look at the call detail records (CDR) https://support.aa.net.uk/VoIP_-_CDRs
The SIP response codes should be shown against each call. Let us know what they are .
If they show differently for 'unobtainable' vs 'busy' then the problem is in your local equipment , otherwise if they are the same then its down to the A & A kit.
greygit1
Re: VoIP question
SIP response codes are only displayed in that output if the call fails to connect (for what ever reason)?
180 !
(whatever that really means)
greygit1
Re: VoIP question
Local equipment. Since it is the phone that leaves the VoIP stuff  which was supplied pre-configured by A&A. I've only changed p/w on that. The rest I just looked at. And scratched my head. Or...
It could be down to how the Hub2 plays. Or how the Hub2 might get upset if it were reconfigured away from its defaults. (Even if those reconfigs/changes are technically correct and the Hub2 is happy to accept those changes).
I can revert the Hub2 back to its defaults and see whether these symptoms go away.
At the moment I can't see it being the switches. Unless they're telling me porkies.
Fixes: 587
Re: VoIP question
180 !
180 is 'ringing'
I thought you said the calls in question didn't connect ? so they should have SIP response codes
Full list of codes here https://en.wikipedia.org/wiki/List_of_SIP_response_codes
Its nothing to do with the Hub 2. The tone that the voip equipment makes is completely down to the SIP response code it receives.
greygit1
Re: VoIP question
Mmm. I misread the A&A webpage.
With a clearer mind I can now see that recent attempts to call the number are not listed, so I can't see the call attempt (let alone any related SIP code).
The tone heard on the handset is an engaged tone (which cycles 4 times before the call is terminated)
Just to make things ever more clear (?) - The handset display showing "Not found" for the number.
(Tried 123 as another test and that returns an engaged tone with the handset display showing "Not available")
I'm wondering whether it is a 'feature' of the handset(s).
greygit1
Re: VoIP question
It isn't a feature of the handsets as far as I can work out. It also doesn't appear to be a feature of the other supplied and preconfigured hardware supplied by A&A.
Might it be a 'feature' of the landline number being transferred to VoIP and associated porting?
Fixes: 587
Re: VoIP question
Sorry, I'm confused now ?Huh
Are you now saying the number has been ported to voip ?
greygit1
Re: VoIP question
This is a voyage of discovery for me.
The number was PSTN and (possibly) ceased when an account was closed. But it may also now be in the process of being migrated to VoIP, but hasn't been (yet).
TBH I'm just as confused Smiley
