VoIP hardware
petermaughan
VoIP hardware
What VoIP hardware should I recommend to a friend?  I bought a SpeedTouch 716v5WL from Free-Online some years ago but now I cannot find any VoIP hardware offered.
Peter
puddy
Re: VoIP hardware
The speedtouch 716wl v5 was a great router but has been discontinued and replaced with the 780 model!
Plusnet may  have some old 716wl in stock
puddy
Moderators note by James_H : Removed full quote of previous post - it is not needed in this instance. : link:rules
pnf
Re: VoIP hardware
The following site sells the Speedtouch 780wl:
http://www.broadbandbuyer.co.uk/Shop/ShopSearch.asp?CategoryID=435
petermaughan
Re: VoIP hardware
Thank you pnf and puddy.
Yes, I have been happy with the SpeedTouch 716v5WL and would be happy to recommend the same or updated version to my friend.
Peter
puddy
Re: VoIP hardware
If he wants to keep costs down a linksys pap2 will cost about £20 and will plug in to a router with a free port
I got mine for £13 from ebay inc p&p
puddy
