Vista says rundll32.exe is infected
- Re: Vista says rundll32.exe is infected
19-10-2010 11:14 PM
The laptop is complaining about rundll32.exe being infected, and do I want to activate my antivirus software. During bootup, it complained about other things being infected, though those messages have stopped once bootup had completed. McAfee seems to be very slow compared to AVG or Avast.
Google comes up with some advert for an antivirus software that I have never heard of before, but if that is part of the problem, then doing anything might be just what the problem wants. Also it brings up the same sort of message as the rundll.exe one, but this one has a long name involving google.
Any ideas what I should do about this, please?
Thanks inadvance
19-10-2010 11:25 PM
20-10-2010 7:17 AM
If Google is misdirecting you then you probably have a DNS changing rootkit; once established these are very hard to detect and remove. When I find (or suspect) one I take out the hard drive and scan it on another computer because they tend to be invisible when the computer is running. The obvious symptom is that when you click on a link provided by a search engine (Google or otherwise) you end up at a different web site to the one the link was supposed to direct you to.
To fix this you need to either:
- Call in a professional.
- Back up your data (and use a working computer to run a virus scan on the back-up), restore your computer to factory settings, install a working antivirus program (after uninstalling McAfee if it was factory-supplied).
An inferior professional would probably follow the second option anyway. If you go to The Tech Guys at PC World they are liable to follow the second option without first backing up your data.
20-10-2010 7:23 AM
20-10-2010 9:32 PM
Before the McAfee run, if I tried to open Internet Option in Control Panel, it would appear and then disappear after less than a second, so I couldn't inspect it, leave alone edit it. After McAfee, Internet Option opened and stayed. I found that something had been added to the Home Page box. I removed that extra bit, leaving just "google.co.uk". I used Apply and OK.
Now when I use Internet Explorer, it says that google "is not set up to establish a connection on port WorldWideWeb service (HTTP) with this computer". It also talks about a Proxy.
Does this give a clue as to what is going on?
Thanks for your help so far
20-10-2010 9:34 PM
20-10-2010 9:38 PM
Quote Macrium Reflect Free Edition is a disk imaging solution for free. A complete disaster recovery solution for your home and office. Protect your personal documents, photos, music and e-mails. Upgrade your hard disk or try new operating systems in the safe knowledge that everything is securely saved in an easily recovered backup file. Macrium Reflect suports backup to local, network and USB drives as well as burning to all DVD formats.
More Here...http://www.macrium.com/reflectfree.asp
20-10-2010 10:47 PM
By downloading the 'iso' file and burning it to CD or DVD, you will be able to boot your laptop/pc using the CD/DVD and this can then be used to scan your entire system off-line.
Note that after the CD boots the default language is German, just click on the Union Jack to switch to English.
21-10-2010 12:06 AM
Security Essentials - http://www.microsoft.com/security_essentials/
21-10-2010 7:51 AM
Quote from: penneck I've made a bit of progress since I started this post. I managed to run McAfee, but it didn't find anything.
Are you quite sure about this? How else do you account for the progress you made?
Quote from: penneck However, now when I boot up, I no longer get any warnings about infected files, nor does Internet Explorer go to some advert for anti-virus software.
Something has found and removed at least some of the malware.
Quote from: penneck Now when I use Internet Explorer, it says that google "is not set up to establish a connection on port WorldWideWeb service (HTTP) with this computer". It also talks about a Proxy.
Yes. In Control Panel or Internet Explorer select Internet Options (in IE this is bottom of the list under Tools). Click the Connections tab then the LAN Settings box. Remove the tick from the box "Use a proxy server for your LAN...". Close the Internet Options window and restart Internet Explorer for luck. Hey presto!
22-10-2010 5:09 PM
You were definitely correct about the Proxy tick in the LAN Settings box. Now Internet Explorer is working correctly.
I have handed the pc back to my son, with the proviso that he lets me know if there are still problems. If he reports back that the pc is okay, I intend downloading AVG and Zone Alarm, and partitioning his hard disk so that he puts his data files on the other side of the partition. I will then take an image of his hard drive, just in case.
Many thanks for your help
