Vista opening links automatically
- Re: Vista opening links automatically
25-01-2009 7:04 PM
My new HP laptop runs on Vista. If I move the cursor across the screen slowly it has a habit of opening some of the links it moves over. The same happens if I place the cursor on a button such as delete. How can I adjust this so it only opens a link if I click on it?
4 REPLIES 4
25-01-2009 7:10 PM
Could be the sensitivity of the touchpad is set a bit high so a minute change of pressure is registered as a tap. You should be able to adjust it in the Control Panel.
26-01-2009 11:25 AM
Thanks for that Denzil. I'll check it out but I think it happens with a remote mouse as well. I know others who complain of the same problem so will investigate further.
26-01-2009 12:29 PM
My neighbour had this problem, and IIRC it was cured by going to Start > Control Panel > Mouse > Activities and disabling 'ClickLock'.
That was with XP - presumably it's similar with Vista.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
26-01-2009 12:46 PM
thanks 4C I'll have a look at that.
