Vista + X-Fi and mics how to?
- Re: Vista + X-Fi and mics how to?
01-08-2007 8:06 PM
Anyone figured out how to get the mic working in Vista with said card in a useable form?
Only way I can get mine working is if I disable HD audio in the bios and that is with What you hear capture device option, so pointless for gaming or voip.
With HD audio I no longer get the mic working, even with Vistas Sound Recorder
Dxdiag for the nosey
FTTP 500 regrade from Tues 28th November
3 REPLIES 3
09-08-2007 10:17 AM
i am an experienced IT Manager, with a home gaming rig with an X-Fi card, but i don't wish to touch Vista until they iron out all the kinks and fix the hardware issues - plus the lack of games that work. Soundblaster cards got a raw deal with Vista and despite ALchemy's release for the X-Fi and EAX cards, i believe there is still trouble. ALchemy re-enables the 3D surround audio features and EAX in games.
have you tried the Creative Labs euro website to see if there have been any fixes/updates to the software available?? The issues are mainly die to DX10, and change from DirectSound to OpenAL sound distribution.
http://uk.europe.creative.com/support/downloads/
According to them, Vista drivers are dated 30th May 07 and ALchemy is dated 8th Aug 07.
09-08-2007 12:18 PM
ALchemy is for the older games just get get EAX audio but yeah tried everything from creatives forum and nothing works, £125 down the pan as it was bought for gaming in mind.
I don't have XP to dual boot just win2k but for my New pc the drivers are worse for win2k than Vista's, so in short term I've taken my nice X-fi card out and reverting to onboard which works with no hassles in Vista, just the audio in game via my 5.1 headphones just isn't as a good but atleast the mic works.
09-08-2007 4:22 PM
might be worth contacting Creative themselves in the UK and see if there is something they can suggest (or spend £60 on a XP upgrade CD!!).
failing that a nice email to PCZone or PCGamer may render some results. I haven't found a working solution other than trying the drivers that they have so far.
