Viruses
evewebber
Viruses
After I have done a scan with McAfee and viruses have been detected and quarantined, how do I find out what files the viruses were attached to so that I can ensure that I do not repeat the problem?
Many thanks.
1 REPLY 1
Pete11
Seasoned Pro
Fixes: 4
Re: Viruses
Don't the infected files go into a Quarantine section?...if so, you should be able to see which files were infected and from that, the programmes too.
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
