Virus loop problem - Help Please?
Hi folks
I am having a bit of a ‘mare’ with a pal’s computer. He has managed to get infected with Antivirus 2009 /360 and I am having a hell of a job getting rid of it.
I have the latest versions (with up to date signatures) of Malwarebytes and Kaspersky on his machine and both are spotting the problems killing various files and then finding one that requires a reboot to kill.
After the reboot the same file is recognised again and there is a request for a reboot to kill it and so it goes on. The virus seems t be in a file called userinit.exe Having looked on the net it seems that deleting it isn’t a good idea as then folks can’t logon at all and get in to a loop that probably requires a reinstall.
All the articles I have seen suggest that malwarebytes can take this nasty out but it isn’t happening here. Have any of you dealt with this issue and are able to offer advice?
Cheers
Peter
3 REPLIES 3
Re: Virus loop problem - Help Please?
It should be easy to get rid of I have done it a few times for people for detailed instruction try
http://www.2-spyware.com/remove-antivirus-2009.html or
http://www.bleepingcomputer.com/malware-removal/remove-antivirus-360
The key to success is to kill the process first as if its still running it will lock attempts to delete files
Follow the instruction on the first link when you have finished check again that its not running dont reboot run Malwarebytes  and see if it detects anything if it does make a note of the reg keys and files.
Kill the memory process again.
Check the files arnt read only and that the reg key isnt set to no access for everyone
pnf
If System Restore is switched on, does switching it off help with the clean up process?  It might be worth running msconfig to see if there are any startup processes or services that look suspicious and stop them.  Is it possible to do the clean up in safe mode?  Do you have the ability to boot the PC from CD and to scan the partitions 'off-line'?  In the past I have used Bart PE (XPE) with Avira Antivirus installed on a CD to do this.  Whether something like that might help I'm not sure as I've never actually dealt with that specific virus, but it might be worth a try if all else fails.
Quote from: Samuria
Cheers Sam I will give this a go. I won't be able to get to it again until Saturday but I will let you know what happens. It does surprise me that both those AV products can be so easily defeated mind you!
