Virus Scan
- Re: Virus Scan
Virus Scan
01-05-2008 6:29 PM
I'm running a scan on my PC. Why is it that when the PC isn't running a scan things go fast but
w
h
e
n
t
h
e
s
c
a
n
i
s
w
h
e
n
t
h
e
s
c
a
n
i
s
5 REPLIES 5
Re: Virus Scan
01-05-2008 6:35 PM
Because the virus scan is using processor power and memory.
If you press Ctrl Alt Del and select processes you can see what is running and how much processor power it is using
Re: Virus Scan
01-05-2008 7:13 PM
r
u
n
n
i
n
g
i
t'
s
slow?
Ah, at last! It's finished
r
u
n
n
i
n
g
i
t'
s
slow?
Re: Virus Scan
05-05-2008 12:06 PM
I'm sure Oldjim meant Ctrl Alt Del, then Task Manager, then Processes.
Re: Virus Scan
05-05-2008 4:48 PM
i vaguely remember that i would run a virus scan on boot late at night, so it worked while i slept. can't recall how i managed that. that way the scanner has the processor to itself, without the cruddy operating system getting in the way.
Re: Virus Scan
06-05-2008 10:27 AM
I also have my scan done in the dead of the night. AVG has a scheduler that allows you to specify times for updates and scans, so mine does an update at 4am, then a full scan at 5am. It's simple, but effective.
