Virus Programs
- Virus Programs
Virus Programs
11-06-2014 11:34 AM
Although I briefly tried it for a few weeks, I have not been at all keen on this idea, as I always understood that more than one anti-virus program would both slow the computer down and they would conflict with each other.
Please, what do the Windows Experts think?
If only one program, which is the better of the two to run?
I use Linux a lot, but do want my Windows7 installation to be as safe as possible.
Many thanks for any advice.
Keith
Re: Virus Programs
11-06-2014 12:00 PM
in addition i run Malwarebytes free & Ccleaner and have never been compromised , Best combination you can use
Re: Virus Programs
11-06-2014 12:13 PM
All work well together but with Malwarebytes, CCleaner & SpyBot you must do manual updates and ran the scans yourself, too.
I have MSE to scan once a week on a Wednesday afternoon and then manually do the other three once that's complete.
Forum Moderator and Customer
Re: Virus Programs
11-06-2014 12:52 PM
Microsoft Security Essentials comes out last and is labelled being by doing more harm than good by letting you believe that you're protected when you're not!
Kaspersky comes out top and Avast is 5th!
York.
Re: Virus Programs
11-06-2014 4:46 PM
Re: Virus Programs
11-06-2014 5:02 PM
Quote from: NedLudd There is an Antivirus Megatest in the current edition of Computer Active.
Out of interest who came 2nd 3rd and 4th?
Regards
Mike
Re: Virus Programs
11-06-2014 5:23 PM
Quote from: rongtw Sorry Nedlud but i care to differ , despite what so called independent test say , MSE works 100% fine and like i say have never !!! been compromised at all in the last 3 years i have used it
That is your opinion based upon your usage. CA have produced their results for people to make their own judgements.
MSE missed 40 out of 100 threats.
1) Kaspersky missed zero
2) Norton Internet Security missed one
3) ESET Smart Security missed five
4) McAfee Internet Security missed one (but expensive)
5) Avast (Best Free) missed 9
York.
Re: Virus Programs
11-06-2014 5:26 PM
Regards
Mike
Re: Virus Programs
11-06-2014 9:18 PM
I'll have to do a bit of thinking about the suggestions!
Cheers.
Keith
Re: Virus Programs
11-06-2014 10:10 PM
I use Avast! Free with Microsoft Defender and Malwarebytes. No problems.
Re: Virus Programs
12-06-2014 8:02 AM
I never use Spybot any more because it went into a decline and has been superseded by other software that runs much faster. These days what you need is software that can find and remove programs that have a veneer of legitimacy and thereby escape the notice of conventional security software. Malwarebytes classifies these as PUPs, Potentially Unwanted Programs
Most security software running on Windows 7 will disable Windows Defender. That includes Microsoft Security Essentials. To check you can look at your Windows Update History to see if Windows Defender definition updates are being installed.
Re: Virus Programs
12-06-2014 11:24 AM
Quote from: ReedRichards I see more virused computers running McAfee than all other security software put together. If it was rated number 4 in a test then that test cannot be of any real-world scenario.
According to CA MacAfee have released a new version with vast improvements!
But, you should also bear in mind, that all the tests performed are exactly the same on all checkers.
Why so called professionals baulk at independent tests beats me!
York.
Re: Virus Programs
12-06-2014 1:31 PM
You are right, McAfee is the worst out there, so much so that the guy that made it, was glad to have his name removed from it, after INTEL yes INTEL purchased & re-branded it,
Quote from: TORPC
<snip>
Even Intel which has taken over Mcafeeare orhave dropped the Mcafee brand name (will see if I can find the link)
The recommendations would be either
Avast free or Microsoft Security Essentials (MSSE) not both for the main resident AV
<snip>
Edit:
[quote= http://upstart.bizjournals.com/entrepreneurs/hot-shots/2014/01/07/intel-drops-mcafee-name-from-software.html]John McAfee is finally glad to be rid of his embarrassing association with McAfee antivirus software.
[quote= http://www.bbc.co.uk/news/technology-25631183]His response to Intel’s rebranding was pure McAfee: “I am now everlastingly grateful to Intel for freeing me from this terrible association with the worst software on the planet,” he told the BBC. “These are not my words, but the words of millions of irate users. My elation at Intel’s decision is beyond words.”
I know people still refer to it as McAfee & that is right for prior to INTEL's re-branding
Therefore in the test that was mentioned above / below (depending on your settings)
McAfee or INTEL's re-branded version ?
Re: Virus Programs
12-06-2014 1:54 PM
York.
Re: Virus Programs
13-06-2014 6:31 AM
Quote from: NedLudd Why so called professionals baulk at independent tests beats me!
I baulk at test results that contradict my own experience. If
Quote from: NedLudd ... MacAfee have released a new version with vast improvements...
that's because it needed to be vastly improved. I have not encountered this wonderful new version yet. Is it incorporated into Plusnet Protect, I wonder?
