VirtualBox on OSX
- Re: VirtualBox on OSX
VirtualBox on OSX
22-10-2014 6:06 PM
It's all a bit strange at the moment.
22-10-2014 6:17 PM
22-10-2014 6:40 PM
22-10-2014 6:41 PM
22-10-2014 6:55 PM
Can I go full screen with the VM ?
I've had a quick mooch but not found the option yet
22-10-2014 7:06 PM
Crossover could also be another option if you want to run certain bits of windows - is it anything in particular?
Parallels you can run in a window, full screen or coherence (where win apps appear as any other os x app)
CMD+F should take it full screen in virtualbox - but quite buggy iirc.
22-10-2014 8:09 PM
Not sure I need to run the thing full screen, maybe looking at moving sage pay over for the good lady to use, but I need to make sure It would work and also be secure. I see the windows updates are lightening fast as normal
22-10-2014 8:30 PM
22-10-2014 8:44 PM
22-10-2014 8:50 PM
23-10-2014 10:51 AM
Quote from: vilefoxdemonofdoom You mean you have to pay money for parallels!!!!!!!!!!!!!
Just as you have to pay for the M$ OS's running under it, and any client access licences etc etc etc.
23-10-2014 11:58 AM
I'm glad I retained the key from my old laptop now before consigning it to the bin, windows that is...
23-10-2014 12:14 PM
23-10-2014 1:23 PM
Happy days....
