Virtual Memory
valart
Virtual Memory
I just wondered if I should increase my virtual memory at the moment it stands at Initial Size 175  Maximum Size !500,A message  came up the other day saying that it was increasing my virtual memory on my computer iif it needs to be increased how do I increase it.
Re: Virtual Memory
Need to know the following before we can answer...
Windows version?
How much memory do you have?
For XP I tend to use 1.5x memory up to a max of 2GB and I tend to set it as the min/max value so the swap space does not fragment.
valart
Re: Virtual Memory
I have XP windows and my memory is 1GB
techguy
Re: Virtual Memory
Personally I just leave it on system managed so it can shrink and grow as needed
pnf
Re: Virtual Memory
The following blog is all about Virtual Memory:  http://blogs.technet.com/markrussinovich/archive/2008/11/17/3155406.aspx
The final section is entitled " How Big Should I Make The Paging File?".  The information prior to it explains the concepts.
Re: Virtual Memory
Do you have a second drive or partition as setting the virtual pagefile to another drive can help performance
