Virtual Box and USB Devices
- Re: Virtual Box and USB Devices
04-02-2013 9:41 PM
Just thought I'd pop in with a quick question for the people who know, Daughter got an Ipod for crimbo now she's hassling me to sort out itunes to back up, put her stuff on etc. Can't be bothered having to pull my work laptop out the bag all the time and wait forever to it boots up. I've decided to download both itunes and Blackberry Desktop Manager to use in Virtualbox on my Precise install. You've probably guessed by now that I need to install guest additions and expansion pack. I'm pretty sure I already have guest additions, at the time to make xp run in full screen.
So anyway I've noticed that I'm running Virtualbox 4.1.12 which is the stock one from the repo. The latest edition from the Website is 4.2.6. Just wondering firstly if I install 4.2.6 from a downloaded Deb is it going to totally wipe my existing installation? I have XP and Mint 13 as guests and that's really going to be a pain to have to install and update all over again. If I don't update VB do I need to find guest additions and expansion packs to got with the 4.1.12 version already installed or will the most recent ones for 4.2.6 work ok?
BTW I followed the instructions from the link above to add 4.2.6 to my repo but can't seem to find it "(Up to version 3.2 the packages were located in the non-free section, starting with version 4.0 are located in the contrib section)" Where do I find the contrib section?
I've had things running far too sweet for a long time to rocks things up As you are aware I hate problem solving computers, drives me
04-02-2013 10:04 PM
You should have a package available for the guest additions. On debian this is called virtualbox-guest-additions-iso, it's probably the same in ubuntu but an apt-cache search virtualbox will show you the available packages.
It would be unwise to mix different versions of the guest additions and virtualbox packages as I expect they are tailored to work with each other.
Once the package is installed there should be an option from the window containing the running VM to install the guest add-ons, this usually just mounts the iso in the virtual cd drive and autorun does the rest.
On the Mint VM you probably want to (if you haven't already ) install the following packages:
- virtualbox-guest-dkms
- virtualbox-guest-utils
- virtualbox-guest-x11
HTH
04-02-2013 10:17 PM
04-02-2013 10:23 PM
I'm not familiar enough with the ubuntu package manager (unless you go to a terminal and use plain ol' aptitude, then it should be a case of searching for virtualbox and picking 4.2 from the available versions). After you added the VB repository did you force an update of available packages?
The two extension packs will be for 32 and 64bit host OSes so pick whichever is appropriate for you.
04-02-2013 10:30 PM
No I never, how do I force an update? I installed the extension pack btw. Ubuntu is still picking up the ipod and not the guest xp. The alternate extension pack when I tried that was just the same. It said already install do I want re-install so just clicked no. I'm reading somewhere it may be to do with priveliges!
Quote After you added the VB repository did you force an update of available packages?
I'll try re-booting and see if that helps.
04-02-2013 10:36 PM
You'll also need the instructions here: https://help.ubuntu.com/community/VirtualBox/USB so that you can use USB devices in VirtualBox
04-02-2013 10:45 PM
04-02-2013 11:13 PM
04-02-2013 11:35 PM
Other than that, I'm out of my comfort zone, time for someone more Ubuntuy to take over the thread
04-02-2013 11:52 PM
Wow, wow and wow. Now I wish it wasn't so late so I could spend the night loading apps Thanks again mate job sorted!
05-02-2013 10:10 PM
*edit my bad was putting wrong username in now I just need to work out how to use my cd drive in a virtual environment. Nothings ever simple!
*edit 2 Managed to get things sorted out, got the cd player working with the guest rather than the host. It would appear that if I import a music CD into itunes it won't the do another right of the bat unless I exit itunes and restart it. Off to bother the itunes people now. I'm fairly confident it's a problem with that rather than virtualbox though.
On a positive note virtual box says that it can't write files from from discs when in pass through mode but apparemtly that's not the case it would appear Finally is there a way I can let my daughter access my xp host from her user account or would I have to set up Vbox and a whole new xp install just to use itunes? Sounds unlikely buy you never know!
06-02-2013 9:51 AM
You would probably need to add her to the vboxusers group, change the permissions on the xp folder (VM), and then give her a shortcut to the XP machine on her desktop.
Not tried it but that sounds like it would work.
06-02-2013 10:35 AM
Seems a bit nuts having to put another full working copy of xp on there just so she can use Itunes.
I was looking into how Ubuntu deals with the ipod to see if it was just a case of me dragging and dropping music onto it as a usb storage but the ipod file system is very complicated to say the least. It's quite hard to work out exactly where the music files should be.
What do you guys use for ripping cd's these days? I've been using juicer. Importing directly through itunes in the guest creates quite large files even with the quality turned down a bit. I had the settings on mp3 high and the resulting files were still about cd size 700mb ish.
06-02-2013 11:15 AM
I use http://guayadeque.org for my music collection, It is supposed to handle ipod's as well. (I only have a 1st gen shuffle and it is supported, once I kicked the auto mount script about a bit.)
I haven't ripped a cd for a few years now, but (just checked) k3b will rip with id3's etc.
06-02-2013 12:33 PM
AFAIK all versions from 10.04 upwards had built in support for IPod/IPhone. Applications such as RythymBox should sync with the IPod. Have a look here https://help.ubuntu.com/community/PortableDevices/iPhone
Quote I was looking into how Ubuntu deals with the ipod to see if it was just a case of me dragging and dropping music onto it as a usb storage but the ipod file system is very complicated to say the least. It's quite hard to work out exactly where the music files should be.
