Virgin media
- Re: Virgin media
Virgin media
โ09-05-2017 6:57 PM
My neighbor has VM tivo box and their internet , has just been put on their 200 mbps speed , he is trying to cut his costs down, asked about reducing his speed, and was told the tivo box needs minimum of 100 mbps to run ????
Anyone know if this is correct
Re: Virgin media
โ09-05-2017 7:00 PM
if yes then it's probably because it's doing most of it's work over internet, and/or the box is packaged with having 100Mbps internet package.
or... they could be talking rubbish.
Re: Virgin media
โ09-05-2017 7:20 PM
Is the 100Mbps package not the minimum that VM do?
Re: Virgin media
โ09-05-2017 7:24 PM
@Mustrum No - both my mum & a friend of mine on 50Mbps, having been 'upgraded' from 30.
Re: Virgin media
โ09-05-2017 7:26 PM
http://www.virginmedia.com/shop/broadband/broadband-only.html
Re: Virgin media
โ09-05-2017 7:29 PM
Re: Virgin media
โ09-05-2017 7:34 PM - edited โ09-05-2017 7:36 PM
Re: Virgin media
โ09-05-2017 7:37 PM
Mum certainly is, although at her last contract renewal they tried (unsuccessfully) to persuade her to go for a faster package at greater cost, but as she really only uses the TV and phone, I battered them into leaving the speed as it was - and got a better package price at the same time.
I think Lin did exactly the same, but got to stay as she was by threatening to move to SKY.
Re: Virgin media
โ09-05-2017 7:57 PM - edited โ10-05-2017 1:23 PM
Was reading chencks link and it says 100 mbps is ok for up to 9 devices .
So the tivo box does not require the 100 but its the minimum they do ๐
On the phone its not so good asking Mr Google, but will check when at home , thanks all ๐
Re: Virgin media
โ10-05-2017 1:21 PM
100Mbps broadband is the entry level for new customers, anyone that's on less than that is on a legacy package.
