Virgin Cable & Belkin Router
- Re: Virgin Cable & Belkin Router
12-02-2010 11:08 AM
Hi all
I am heading to my sisters later and she has Virgin Cable Broadband. She currently plugs in an ethernet cable when she uses her laptop as she didnt take a wireless router when she signed up.
My question is....I have an old Belkin Wireless G Router lying around (with built in ADSL) can i use this router as a bridge to allow her to use its wireless capabilities?
Thanks in advance
Mark
Thanks in advance
Mark
2 REPLIES 2
16-02-2010 6:54 PM
Maybe, maybe not - it depends what the particular router can do. Do you have a manual for it, or a model number?
16-02-2010 7:03 PM
In general the answer is likely to be probably not, or only with a lot of detailed command-line tinkering with the configuration.
