Viewing networked XP computer from Win 10 pro 64 bit
- Viewing networked XP computer from Win 10 pro 64 b...
- « Previous
- 1
- 2
- Next »
Re: Viewing networked XP computer from Win 10 pro 64 bit
05-06-2017 1:33 PM
Yes, IPV6 can cause issues.
Start at the start: from a command prompt, try "ping <xp's IP address>": you should see a response (use "ipconfig" on XP machine to view its IP)
Try opening a file browser, and connecting to "\\<xp's IP address>\c$" - if you are lucky, you'll be asked for credentials, and you'll see the c:\ listing of the XP machine. If you get that far, then your network and inter-machine connections are fine, it's now "a windows problem" 🙂
14-06-2017 10:06 PM
27-06-2017 6:04 PM
You aren't going to believe this
I haven't changed anything but suddenly it works
- « Previous
- 1
- 2
- Next »
