Video on website wont show
shutter
Fixes: 65
I have just finished loading up a new HDD with Windows Vista Home Premium.... AND.... all my other useful programs... which took forever, ... almost finished, just a couple of other small progs on CD to load up, so thought I would entertain myself by watching a couple of vids on line..
Youtube vids show ok...
however on another site... when I want to view the vid.... I get a black screen where the vid should be, with a message in the middle, something like...
(point of interest...... the vids show ok, on my original HDD on the same site.... so not a problem with the site... )
This needs Adobe Flash player 9.0.124 or later to run..... and a linky to Adobe download.... clicked on that and downloaded the latest version 11. ? ? ? something...
back to the vid.... same black square... but no vid... and no message..
Also tried to install Shockwave.... but got this message after a while of install running...
Error
The windows installer service could not be accessed. This can occur if the windos installer is not correctly installed. Contact your support personnel for assistance.
So... shut down, and inserted the Windows CDrom.... clicked on "repair"  and let it do its stuff.... nearly finised it, and get a screen saying that did I want to go back to a "restore" point... so clicked ok... and eventually the "repair" finished...
back to the vid.... but still says the message about 9.0. 124.
I have unistalled version 11 ? ? ?  ..... and re-installed it.... still no vid... (still youtube is ok)...
any ideas?  ..... I`m not looking forward to doing a format, and re-installing windows and all the work I did yesterday adding in my other progs....
20 REPLIES 20
Oldjim
Resting Legend
Fixes: 63
Re: Video on website wont show
Try Firefox
shutter
Fixes: 65
I am using firefox as my browser......
On both HDD`s.... the two are almost a clone of each other....
((so what works on the old one,..... should work the same way on the new one)) ....
.same OS. and same progs....
The reason for the new HDD is because I want to format the "old" one, to use as a stand alone external HDD for my photography files and folders over the last 5 years....
Oldjim
Resting Legend
Fixes: 63
Do you have this in your plugins
shutter
Fixes: 65
Hmm....not sure.... it is on this HDD... so you may have found the answer......
will have to shut down this one, and insert the "new" hdd......
watch this space....... (no video codec required  Cheesy  )
shutter
Fixes: 65
Now using the "new" hdd...... and yes I do have that shockwave installed, and active....
Oldjim
Resting Legend
Fixes: 63
unless it is a bit embarrassing why not provide a link to the site  Grin Grin
shutter
Fixes: 65
Ha Ha !....
Grin tried another site,.... and got this message...
Plugin container for firefox has stopped working..... a problem caused the program to stop working correctly. windows will close the program and notify you if a solution is available.
so went back to plugins, and noticed I am running FF 8.0 xxx..... thought it might be the problem.... and went to Google to get FF 9.0.1...... installed that and that has solved the problem.....
(and no , I`m not going to tell you what site it was....  Shocked   you will have to keep guessing.... ! ! !   Cool Cheesy )
Thanks for the help....  Wink
Oldjim
Resting Legend
Fixes: 63
I am on Firefox 14 - it's about time you got up to date
kmilburn
I've seen a similar problem with flash recently,  it looks like the latest version has dropped support for older versions of Firefox.
shutter
Fixes: 65
Sometimes being "Up to date" is the cause of the problem..... some of the addons that I had/have are no longer compatible with ff14, so I have stayed away from upgrading ....
anyway, it is working ok now... so no need to upgrade any further....
Thanks again for help.  Smiley
ReedRichards
Seasoned Pro
Fixes: 25
So what did you do to get it working?  In my opinion, it's bad manners to ask for help then not reveal the solution.
shutter
Fixes: 65
@ ReedRichards....... Shocked
the clue is in this reply somewhere.........  Undecided Undecided
Sorry for my "bad manners"....  Cry Cry Cry
Quote from: shutter
Ha Ha !....
ReedRichards
Seasoned Pro
Fixes: 25
Oh yes.  You didn't want to follow Oldjim's sensible advice to load the latest version of Firefox (14) so edged up from version 8 to version 9.  Retro!
And I think your posts have come down with a bad case of the measles.
Mav
Fixes: 515
I've noticed that Flash crashes more frequently these days whether in Firefox or Chrome (rarely use IE) - latest versions of each.
Strange, though, according to Programs and Features I have 11.3.300.270 installed yet Adobe website indicates that the latest version is 11.3.300.268!
Forum Moderator and Customer
