Video files - burn fails
Fixes: 62
I have been using Nero 7 OEM and a Samsung SH-S203P SATA DVD drive to burn video and ISO images without problems.
Firmware is up to date and I am using Vista 64 bit
However for the last few weeks the burns have failed with this error
#27 CDR -1046 File Writer.cpp, Line 303
Illegal disc
G: TSSTcorp CDDVDW SH-S203P
11:14:19    #28 Text 0 File DVDR.cpp, Line 3783
EndDAO: Last written address was 63 (3Fh)
11:14:19    #29 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 12x (16,620 KB/s)
I have tried dropping the burn speed to 4X but it hasn't helped.
I can copy the files to my XP computer and burn there with Nero 6 without problems.
Is it likely that the drive is starting to play up or something has gone wrong following one of the Vista patches
7 REPLIES 7
VileReynard
Champion
Fixes: 17
Re: Video files - burn fails
Is it worth trying cleaning the laser optics for the drive?
It would explain an ability to read, but not write.
gordo
Sounds like it is nero, if you can burn with a lesser version,  the drive is not liking something in the set up,  I always use Ashampoo burning Studio, does the job with out the clutter of nero with which I always seem to get problems especially since switching to a lightscribe
Fixes: 62
That could be unfortunately with Vista 64 bit I am somewhat limited - thought (heresy I know)  - doesn't vista include a burning tool- must check
gordo
I am no vista expert, I haven't even seen it in operation.  I think you are right, it has a burning tool, based on Roxio.  just off the top of my flies landing ground, could the two Roxio and Nero be causing a conflict.
I notice reading around that several others have had or got this problem all using different makes of Burner.
I don't know what you want to burn and whether this would be any help. but it is my favourite F word    FREE
http://www.imgburn.com/index.php?act=news#news
Fixes: 62
Just tried imgburn - worked like a charm.
Except that flaming noise when it finishes - I had the speakers on  Grin
Thanks for the help - looks as though it is Nero and Vista 64 bit  Angry
Fixes: 27
A while ago, I had ROXIO installed, then someone suggested, and loaned me their Nero disc.... on the setup it complained that there was a conflict with ROXIO and it must be uninstalled before Nero could be installed and run correctly.... so you may be finding, as someone said, a conflict with the VISTA 64 burner..............
gordo
glad it worked.
