Video editing software?
- Re: Video editing software?
on 05-06-2017 2:32 AM - last edited on 05-06-2017 3:00 AM by Mav
I've taken a couple of vids indoors on my G4, but a bit too dark.
Can anyone advise me the best/easiest way to adjust/edit this please?
Edit.
Don't understand why the title is showing "software for Mac"
That isn't what i typed
Moderator's note by Mike (Mav): Changed thread title to.
05-06-2017 6:56 AM
@foxleybob - If it is a Mac then there is the iMovie software that comes with it. I asked a similar question myself for editing Dash Cam footage and I was told of this (having removed it from my Mac as I thought it was a player and not an editor). If its not for Mac then other recommendations will follow.
05-06-2017 8:18 AM
Here's what I use for editing...and it's free, not easy to use though but once you master it gives great results.
VSDC Free Video Editor
By the way, make a back up of video and use that to practice with, then you won't ruin the original.
Growing old is inevitable...But growing up is optional.
05-06-2017 8:29 AM - edited 05-06-2017 6:06 PM
@foxleybob Avidemux 2.6 free... http://fixounet.free.fr/avidemux/
Click on "downloads" and scroll down for your O.S. download.... Linux, Mac, Windows... etc etc...
load video
set output format..... ( last choice left pane) default is AVI Mux
click Video on top toolbar
select Filter
Select Colours
double click Contrast in the menu pane
move the slider under the square to view the video... adjust the contrast and brightness as necessary..
click OK bottom right
click "close" on "filter" window
Click > on the player to run ... then "save" or "save as"...
You can chop bits using the [A marker at start of edit and the B] to end the edit...
your original is kept in the original location... you are using a copy... when saving rename it as "XYZ Edited" or whatever to distinquish it from the original
05-06-2017 9:13 PM
No, it's not a Mac, using Windows 7
As i said in the post, I didn't know why the title said what it did
Don't think it was a typo.
05-06-2017 9:15 PM
Thank you Pete11 and Shutter.
I'll have a closer look when time permits
05-06-2017 9:19 PM
@foxleybob - I think the name of the original post was changed by the auto complete when you created the post and maybe you didn't notice it. In fact it may well be the title of the post I made regarding editing software.
06-06-2017 12:33 AM - edited 06-06-2017 12:35 AM
Really?
Interesting, so it has a predictive text
Edit.
Well it must have then because I didn't put the "Huh" smiley in
06-06-2017 4:43 PM
Strange the title has changed correctly this time.
Magic or Mod intervention I ask myself
