Video Juke Box?
Video Juke Box?
I've just had my son come in to ask if we could go to Ikea this weekend (after the shivering had washed over me) I asked what we was wanting. 'I need another set of shelves for my DVDs' came the reply. But to cut a long story short my son has in excess of 500 DVDs and BlueRays and I was wondering if there was any software / hardware that could be bought that would allow the creation of what would be a Juke Box for movies.
I understand there are issues regarding copying etc, so it may not even be possible but as a concept it makes perfect sense to me.
19 REPLIES 19
Fixes: 1,483
Re: Video Juke Box?
rip them all do hard disk and use plex https://plex.tv/
Re: Video Juke Box?
Now that is an impressive bit of software. Have a gold star for the suggestion. The next step is to get a NAS that's up to the job.
shutter
Fixes: 65
Re: Video Juke Box?
Gonna take a while..... so you might as well put one in the telly and watch it, while you doe "some" of the other 499 !!! ... Cheesy
Re: Video Juke Box?
Yes, that is an obvious consideration. I don't really know what software's needed to rip DVD's / BlueRays but I suspect Google does. Out of curiosity does anyone know how long it takes to rip a DVD?
Fixes: 1,483
Re: Video Juke Box?
dvd's not long at all and lots of free software to do it.. blu's on the other hand take considerably longer.
VileReynard
Fixes: 20
Re: Video Juke Box?
You need to pay for the pleasure of putting everything in somebody else's cloud.
Why not get a 2TB disk (or bigger) and use an old PC to stream it to your TV.
There is free software which will do this over your local ethernet.
Re: Video Juke Box?
I already have a large QNAP NAS but this was to be a standalone solution hence the 'Video Juke Box' reference.
There is software as you say, Plex for one, but the level of interest was sitting at -1 when I suggested it. I think the thought of transferring all of the DVD's to disk nullified the value of the solution!
twocvbloke
Re: Video Juke Box?
The way I see it is if you already own the discs, just use a P2P downloader to download the already digitised copies of them and store them on your media server, the DVDs are just hard copies, and you do have the right to make digitised copies for use on personal NAS and media servers, so if someone else has done the work save yourself the task and download instead... Smiley
(I'll just apply my flak jacket for the ensuing attack for daring to mention downloading movies that you already own!!)
VileReynard
Fixes: 20
Re: Video Juke Box?
Where do you find identical copies of your DVD's on the internet?
Strat
Fixes: 565
Re: Video Juke Box?
Quote from: twocvbloke
As I understand it you don't own the DVD/Blue-Ray and it's content, you have purchased the right to listen/watch the content.
Just a thought.
VileReynard
Fixes: 20
Re: Video Juke Box?
You have the right to sell the DVD - so you must own it!
twocvbloke
Re: Video Juke Box?
Quote from: vilefoxdemonofdoom
Open your chosen search engine, enter the DVD title and "download" as the search terms, hey presto, loads of results, amazing how so many people don't know of this simple task... Grin
Quote from: Strat
Therefore the right to watch what you have purchased covers a copy that has been downloaded to use on a personal media player and not used for commercial or fraudulent use (such as burning off knockoffs to flog at your local dodgy delboy market stall), you're allowed to make backup copies of media you have purchased, and those backups can be physical or electronic media, but only for personal use... Smiley
pwatson
Re: Video Juke Box?
So using somebody else's 'backup copy' is not allowed then...
twocvbloke
Re: Video Juke Box?
If someone else's backup copy comes from the same release as your original, there's no difference as to whether you made it or they made it, it's the same DVD pressed in the same factory, the only difference is you didn't spend weeks converting everything to files readable by Plex... Smiley
Now if say you had a DVD version of a film and then downloaded the BluRay, then yeah, that's not allowed... Wink
