Viber for Android
- Re: Viber for Android
Viber for Android
12-01-2015 6:05 PM
I have searched for further information on these fora but it is sparse. What I did garner is that certain ports on the router may need to be open and Viber uses VOIP - have I got that right?
What are the pitfalls of using Viber?
Anyone care to comment, please?
Forum Moderator and Customer
12-01-2015 6:16 PM
Seems ok.
I didn't have to open any ports.
12-01-2015 6:23 PM
She does use Skype but most of her friends seem to use Viber for voice-only calls.
12-01-2015 7:02 PM
12-01-2015 7:40 PM
13-01-2015 3:16 AM
I haven't used them for years.
13-01-2015 10:41 AM
Setup is easy, just need your details and p/w. If you haven't used them you will probably need to create a new password for the phone.
13-01-2015 12:13 PM
13-01-2015 5:17 PM
It was too hard for me.
13-01-2015 5:25 PM
I've just moved over to voiper http://www.zoiper.com/en on my Nexus7, was using CSipSimple but it started playing up after an update. Seems to be available for most platforms...
Alternatively http://en.wikipedia.org/wiki/List_of_SIP_software#Free_and_open-source_license_2
