Verbatim DVD-R
- Verbatim DVD-R
Verbatim DVD-R
17-12-2013 3:28 PM
I Have had about 5 batches of these discs (50 Pack, printable) over the 3 years and all have been ok apart from the last pack purchased from Amazon.
Looking at feedback on the Amazon website this seems to be a common problem and there is no way as far as I know of checking if a blank disk is OK before burning something to it, even if there is a way few people would have the time to check through a whole pack of 50 discs just to make sure they were ok.
Does anyone else use printable DVD-R discs other than Verbatim ?
We are born into history and history is born into us.
2 REPLIES 2
Re: Verbatim DVD-R
17-12-2013 3:41 PM
Yes, I've been using Sony branded ones for a few years. Not bought any recently though, so unsure if things have gone down in quality.
That's RPM to you!!
Re: Verbatim DVD-R
17-12-2013 4:08 PM
I always used ones with Taiyo Yuden dye
