Value of Zone Alarm ?
- Value of Zone Alarm ?
03-06-2014 5:38 PM
I have used the free Zone Alarm on and off for many years. Every now and then, Zone Alarm causes me grief and I uninstall it. Then a few months later I put it back on. I finally got rid of it about a year ago.
I also uninstalled Avast ! at least a year ago because it also sometimes caused problems, and had installed in its place Malware Bytes which I have had to run manually since then. Then recently I caught a virus because I had been relying on Malware Bytes and had forgotten for a while to run a virus check. My own fault entirely.
So having learned my lesson, I re-installed once agaiin both Avast ! and Zone Alarm. Something started to slow my computer down (I am running XP) and grabbing all the resources. Furthermore, images from the internet kept being blocked. Eventually, I traced both causes back to Zone Alarm. So once more I have uninstalled Zone Alarm, and everything is again running smoothly.
I have left Avast ! in place, because it does not seem to be causing any problems (yet), but I wonder whether Zone Alarm really does offer any protection. I know I have read opinions saying Zone Alarm is a waste of space but now that XP is no longer supported by MS, I really do not know what to do.
I know some people will say change the computer but that is not practical for me for a variety of reasons, not the least because it would mean buying three computers and changing my two good laser printers with old parallel ports (I have two residences), and I obviously also carry a laptop in addition to the the two desktop computers. It would also mean buying three new sets of Outlook and Office and the whole process is just not affordable at this time. When one of the computers finally gives up the ghost, I may be forced to think again, but definitely not at this time.
So the simple question is whether Zone Alarm serves any real purpose or not ? I would be interested in views.
Re: Value of Zone Alarm ?
03-06-2014 5:43 PM
Second - for protection the latest results would indicate that Avira is better than Avast but either should protect you
03-06-2014 6:11 PM
03-06-2014 10:34 PM
also as for a AV you cant go wrong with MSE , microsoft and its FREE !
04-06-2014 9:47 AM
You may find this Ask Leo article useful.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
04-06-2014 5:13 PM
Brilliant. Just what I wanted to know. Very helpful article indeed.
rongtw
Thanks for sharing your experience. That is also re-assuring.
05-06-2014 12:08 AM
Basically an outbound firewall will tell you things you would not otherwise know. You may or may not be able to make use of this knowledge. In order to make use of what the firewall tells you, you will definitely need to spend time in trying to make sense of what those outbound programs/processes flagged by the firewall actually do.
05-06-2014 10:38 AM
Thanks again. I had already drawn that conclusion from the article and from what others have said. I will not be bothering with Zone Alarm again. Saves on resources too !
06-06-2014 7:25 AM
06-06-2014 12:17 PM
The OP mentioned that they are running XP still. I have bitten the bullet and decomissioned my XP machine now. You're fighting a rear guard action against MS to keep it going .
06-06-2014 10:42 PM
06-06-2014 10:52 PM
01-07-2014 2:20 PM
Quote from: ReedRichards ...................
The above is the most valuable statement that has been made on this topic!
Windows XP Firewall gives you no outbound protection and I disagree with a number of assumptions and remarks in the Ask Leo article. An outbound firewall could stop you becoming part of a botnet for example! Your router would not!
Unless your machine is that low on resources, it is worth installing a firewall giving outbound protection but you do need to spend time customising the setup and understanding the pop-up messages it may give from time to time.
Later versions of Zone Alarm Free Firewall can be problematic, and on an XP machine I've stuck to using version 6.5.737.000 which has generally given me sterling service and protection for a number of years. It also (by virtue of the pop-up messages) is letting me know when certain installed software wants to "phone home" and so I can decide whether I want it to or not!!
02-07-2014 6:42 AM
A bad analogy for the outbound firewall protection would be like insisting on carrying a parachute with you whenever you fly anywhere. It might save you if you need to jump out of the plane, but it won't protect you from everything like the plane crashing into a hillside while attempting to land. You really don't want to be in the situation where you need to rely on it.
02-07-2014 9:45 AM
But it should be remembered that nothing - no AV, no Internet Security package, whatever is 100% effective. Users need to pick what they have on their machine consistent with machine resources and usage as well as user experience and of course no conflicts with any other packages.
But the main point is, that to give the impression that an outbound Firewall is of no value is complete and utter bollocks.
