VPN
chandu
VPN
Hi Guys,
Can someone tell me what VPN is and direct me to a site which can explain in detail what VPN is?
How does one get VPN?
Many thanks,
Chandu.
9 REPLIES 9
Browni
Aspiring Hero
Fixes: 60
Re: VPN
chandu
Re: VPN
@ Brownie Your post does NOT answer my query!
ITWorks
Fixes: 9
Re: VPN
@chandu see hereSmiley
Browni
Aspiring Hero
Fixes: 60
Re: VPN
It's such a vague question but the answers are available on my link, you just need to use some grey matter.
Fixes: 1,474
Re: VPN
Moderators Note.
Moved to tech help and one reply removed.
chandu
Re: VPN
Thanks, Browne, I did not see your Linky. Lacking the grey matter, I suppose!!!
chandu
Re: VPN
Thanks ITWorks, Very helpful.
steveocee
Re: VPN
VPN's have a very legitimate and arguably a fair few illegitimate reasons to be used.
Do you mind if I ask what task one is doing where you have identified you "want" a VPN yet don't know what they are and how they work?
www.steveocee.co.uk
chandu
Re: VPN
@ steveocee, Thanks for your asking. I have heard people talking about VPN and I was curious to find out what it was and how can one use the VPN. Being OAP with considerable amount of grey matter lacking (as Browni kindly pointed out in his post above), I think I have no need to use the VPN. Our normal PlusNet network should suffice my needs. To all who responded to this query (including Browni), a BIG Thank you to you all. Have a great week (what is left of it) and Thanks.
