VPN not working
zaaxuk
VPN not working
I can not get VPN to working on the internal network, it used to work fine on SKY why not on Plusnet?
Tags (1)
5 REPLIES 5
ReedRichards
Seasoned Pro
Fixes: 25
Re: VPN not working
Different IP address range?  Plusnet routers typically have IP address 192.168.1.254 whilst Sky routers typically use 192.168.0.1 .
zaaxuk
Re: VPN not working
Nope - i've got the correct IP address, and I assume that the routers firewall would not affect anything going though it on this side.
I won't even reply to a ping
VileReynard
Fixes: 20
Re: VPN not working
Not all machines will reply to pings.
https://en.wikipedia.org/wiki/Ping_of_death
zaaxuk
Re: VPN not working
It did until I moved to plusnet
chenks76
All Star
Fixes: 12
Re: VPN not working
sounds like you need to speak to your work IT.
it could be that they are blocking your incoming connection.
