VPN not working
- Re: VPN not working
VPN not working
21-08-2016 6:47 PM
I can not get VPN to working on the internal network, it used to work fine on SKY why not on Plusnet?
Re: VPN not working
22-08-2016 7:23 AM
Different IP address range? Plusnet routers typically have IP address 192.168.1.254 whilst Sky routers typically use 192.168.0.1 .
Re: VPN not working
22-08-2016 10:02 PM
Nope - i've got the correct IP address, and I assume that the routers firewall would not affect anything going though it on this side.
I won't even reply to a ping
Re: VPN not working
25-08-2016 11:28 AM
Not all machines will reply to pings.
https://en.wikipedia.org/wiki/Ping_of_death
Re: VPN not working
25-08-2016 11:29 AM
It did until I moved to plusnet
Re: VPN not working
25-08-2016 11:55 AM
it could be that they are blocking your incoming connection.
