VPN causes Netgear DG834 V4 DOS Warnings after firmware upgrade to 5.1.14
- Re: VPN connection produces Netgear warnings of DO...
20-08-2009 12:47 PM
When I log into my company VPN , of late my Netgear Router produces multiple Security e mail reports (to my + Net address) such as
UDP Packet - Source:192.249.36.104,4500 Destination:192.168.0.2,4500 - [DOS]
UDP Packet - Source:192.249.36.104,4500 Destination:192.168.0.3,4500 - [DOS]
I know I can find setting to turn e mail alerts off, but how do I tell DG834G router this source is safe?
Advice valued
Advice valued
8 REPLIES 8
Re: VPN connection produces Netgear warnings of DOS Security Alerts
20-08-2009 1:01 PM
Is the port number of 4500 fixed? If so my only idea would be that you could on the Services page create a service for this port, then on firewall rules create an inbound rule for that service where you allow the single WAN address 192.249.36.104 with log never.
20-08-2009 1:25 PM
Thanks; 4500 seems constant and I know who the 192 suffix belongs to (VPN Controller);
however ,some Netgear reports are bigger, show other addresses trying to access too;
some are Italian/Polish addresses/may be real threats, that only appear when on VPN which is US based;
UDP Packet - Source:64.200.148.96,1948 Destination:87.115.89.58,60009 - [DOS]
UDP Packet - Source:217.168.141.2,14190 Destination:87.115.89.58,51413 - [DOS]
UDP Packet - Source:79.54.255.101,11803 Destination:87.115.89.58,9527 - [DOS]
20-08-2009 4:11 PM
That's why I suggested a rule that (a) only refers to port 4500 and (b) only allows IP 192.249.36.104
24-08-2009 1:14 PM
This was caused (and vpn speed slowing to snail's pace) by recent Netgear (DG834 V4) firmware update from 5.1.09 to 5.1 14.
Reverting to previous has removed DOS warnings as soon as I connect, and inability to send/receive any e mails over 100kb!
Googling I see other applications have grief with this firmware too eg Skype/games.
24-08-2009 1:26 PM
Thanks for the post - note to self - don't upgrade my firmware
24-08-2009 1:34 PM
yep i upgraded to the latest firmware on the v4 and got the same mis reports that XBOX port 3074 was a dos attack which downgradein firmware again solved as i didnt fancy runing with out dos an port scan protection on currently on 5.01.09
Re: VPN causes Netgear DG834 V4 DOS Warnings after firmware upgrade to 5.1.14
25-08-2009 10:25 AM
I've got two of these routers, one with v3 hardware, the other v4. Both on the latest firmware. The v3 one runs realy fast, any my download speed is much higher than when I swap in the v4 hardware.
25-08-2009 10:30 AM
Aren't those different chipsets?
[me=jelv]Really off the wall: does this in any way tie in with the PPP issues?[/me]
