VPN Ports
- Re: VPN Ports
VPN Ports
10-09-2015 10:43 PM
However, it looks as though the L2TP VPN ports 500, 1701 and 4500 are blocked by PN (I tested the ports on http://www.yougetsignal.com/tools/open-ports/ - see attached), even though the firewall on my PN dashboard is off.
If the firewall is completely off, why is the VPN routing not working? Nothing on the router has changed other than the connection settings.
This is not really acceptable to me.
Thanks in advance.
Re: VPN Ports
11-09-2015 3:30 AM
Have you disconnected and reconnected your router since turning the PN firewall off?
Re: VPN Ports
11-09-2015 6:39 AM
Should I contact PN's Traffic Management department?
adie:quote
Re: VPN Ports
11-09-2015 7:10 AM
I have only ever rebooted the router. Should I have rebooted the modem? Thanks
Re: VPN Ports
11-09-2015 9:09 AM
Re: VPN Ports
11-09-2015 10:21 AM
Quote from: Bob Does your router have a firewall log? I can think of no reason why these ports would be blocked. Am I right to assume it's TCP and not UDP traffic you're trying to forward?
I forward both TCP and UDP traffic.
Yes I've looked at the firewall log but there's nothing listed as traffic doesn't reach the router!
When I try connecting with a client the response is that the server is not responding.
What next?
Re: VPN Ports
11-09-2015 10:34 AM
Quote from: Nobody ... even though the firewall on my PN dashboard is off.
Looks like it's set to 'low' to me, rather than being switched off?
Re: VPN Ports
11-09-2015 11:19 AM
Re: VPN Ports
11-09-2015 11:24 AM
I see no reason why the firewall needs to be configured to 'low' for VPN access so I'd suggest switching it off completely and disconnecting/reconnecting the PPP session before trying again.
adie:quote
Re: VPN Ports
11-09-2015 11:27 AM
