2 Questions
I have a Pluscom VPA-11 VOIP adapter which I havent used in ages and the power supply has become mixed up with others and I'm not sure which one it is. If someone has the same unit could you please tell me what voltage and Amps and polarity it is That info should help me to find it again
I haven't found any website for Pluscom so another question I have is is there any software in connection with this item and where can I get setup instructions
