VOIP Qs
- Re: VOIP Qs
VOIP Qs
21-11-2007 8:10 PM
I have the Broadband Phone 240, does this mean i get 240 free calls to any phone every month?
I dont want the phone to be plugged into the laptop, can i plug a phone straight into my router, it has not got a VOIP port, can i get a converter?
How do i find out what my number is so i can give to friends and family, i keep the bt phone out the socket at present as it kicks the net off.
Help appreciated.
Re: VOIP Qs
21-11-2007 11:16 PM
Quote 1) Thats 240 free minutes per month.
To geographical 01/02/03 numbers. SIP calls between Broadband Phone accounts and other peered providers are free. Anything else is charged for using pre-paid credit.
Re: VOIP Qs
25-11-2007 6:34 PM
Quote from: gavster A few questions.
yes 240voip minutes every month
Quote from: gavster I dont want the phone to be plugged into the laptop, can i plug a phone straight into my router, it has not got a VOIP port, can i get a converter?
You have a great choice start with a phone adapter £20 for a linksys pap2 this plugs in to your router (cable should come with it)
Speedtouch sell routers with voip port with an adapter so you can plug a normal phone in. Plusnet sell them
Quote from: gavster How do i find out what my number is so i can give to friends and family, i keep the bt phone out the socket at present as it kicks the net off.
Dont give your friends the number yet its an 08 number cost 3p per minute and wont come out of a free minutes
Quote from: gavster Help appreciated.
Puddy
Re: VOIP Qs
26-11-2007 12:34 PM
Quote from: puddy Dont give your friends the number yet its an 08 number cost 3p per minute and wont come out of a free minutes
Although if you sign-up for the VoIP Beta Trial you can choose a geographical number with a normal area code (01/02 number).
Re: VOIP Qs
26-11-2007 2:10 PM
Quote from: Bob
I have signed up but hava recived no further info
Puddy
Re: VOIP Qs
01-12-2007 4:39 PM
Another question, i am now on the VOIP beta trail, using the xlite software, how do i use the Call divert feature, so calls to my new 01 number get diverted to my mobile?
Re: VOIP Qs
01-12-2007 6:00 PM
Ian
Re: VOIP Qs
01-12-2007 7:51 PM
Any ideas?
Re: VOIP Qs
03-12-2007 12:47 AM
