VOIP Port forwarding Netgear DG834G
- VOIP Port forwarding Netgear DG834G
07-01-2008 9:54 PM
Has anyone set up the port forwarding for VOIP on the Netgear DG834G please. We THINK we have it right and can receive calls and hear adio in both directions. Can dial out but no audio in either direction.
Any suggestions would be welcome.
1 REPLY 1
Re: VOIP Port forwarding Netgear DG834G
12-01-2008 9:12 PM
What software/hardware are you using and the config you have so far?
http://www.portforward.com/english/routers/port_forwarding/Netgear/DG834G/DG834Gindex.htm
http://www.plus.net/support/broadband_phone/setup/setup_guide.shtml?supportb=bphone_t5xlite
May be of some use.
May be of some use.
