VMBU seems broken again ... (#89275451)
paulh
This relates to the same problem as ticket  #86746794  from June 2014.
VMBU has stopped registering usage since 24/07/2014.
It seems to have coincided with a disconnect/reconnect that occurred a few minutes after midnight 24/07/2014 (I think this was part of planned maintenance on PN's part)
I was reconnected to  195.166.130.152 (lo0.11.central11.pcl-bng02.plus.net) which is my current gateway.
I  assume that as with last time usage that I cannot view will not be counted?
(this is getting very annoying.)
2 REPLIES 2
Pettitto
Fixes: 5
Re: VMBU seems broken again ... (#89275451)
That's right. We've been carrying out maintenance on the affected gateways recently and we're nearly finished with that, so I'm hopeful that we've have the usage issue resolved soon.
Same rules apply that any usage used that isn't displayed but is used, you won't be charged for.
paulh
thanks Chris
