VBScript - IF something equals something
FIXED- Subscribe to RSS Feed
- Re: VBScript - IF something equals something
02-05-2017 11:51 AM - edited 02-05-2017 11:51 AM
i have a simple IF THEN ELSE
IF variable1 = "A" AND variable2 = "B" THEN ELSE END IF
and that works but appears to be case sensitive.
so if variable2 = "b" then it fails.
is there any way to make it so that it'll pass if variable2 is B or b?
(this is just a simplifed version, but variable2 could be a word and not just a letter.
Fixed! Go to the fix.
02-05-2017 12:00 PM
02-05-2017 12:05 PM
this gives two solutions - the one above and the other using string comparison
02-05-2017 12:05 PM - edited 02-05-2017 12:06 PM
how is converting the variable to uppercase going to help?
that would only help if both items being compared were in upper case, which they might not be.
the IF statement needs to be case insensitive.
02-05-2017 12:07 PM
i actually looked at that very page, but came to the conclusion that StrComp may not work 100% of the time.
02-05-2017 12:09 PM - edited 02-05-2017 12:12 PM
You can always use :
IF (strcomp(Var2, "B", vbTextCompare) == 0) THEN ... END IF
When the value returned by the function is < 0 then the Var2 is less than "B" (i.e. A -v- B) when its > than 0 then Var2 is greater than "B" (C -v- B) but when it's 0 then both string are deemed the same regardless of case.
Edit:- Correct type and added this:
Why do you say it won't work 100% of the time?
02-05-2017 12:11 PM
02-05-2017 12:14 PM - edited 02-05-2017 12:14 PM
IF (strcomp(Var2, "B", vbTextCompare) == 0) THEN ... END IFWhen the value returned by the function is < 0 then the Var2 is less than "B" (i.e. A -v- B) when its > than 0 then Var2 is greater than "B" (C -v- B) but when it's 0 then both string are deemed the same regardless of case.
what if it is "b" though (as opposed to "B") ?
or what if Var2 is "SomeThing" and it's comparing it against "something" or "someThing" or "somethinG" ? etc etc
02-05-2017 12:23 PM
Well due to the way the function works an implied case conversion is done to the input parameters, so it can always guarantee you consistent results. By using this method you don’t have to worry about the case of either input as the functions will apply its own logic to deal with that. So take that into consideration when or if you use it.
If Var2 is ‘SomeThing’ then comparing it against ‘something’ or ‘someTHing’ will produce a 0. However if you compare it against ‘somethings’ then you’d get value > that 0.
