Using your TV as PC Monitor
community
Unusually for me, I have some advice to give rather than continually seeking it!!
I took all this morning to find out that if you want to use your TFT TV Monitor as a PC monitor (providing your particular TV will allow that)
you need to match the Resolution of your PC Display setup to the recommended resolution of the TV manufacturer.
I was continually getting a ""Unknown Format" notice on my TV screen, so I sat down and read the TV manual.
Mine (Sanyo TFT 26") will not recognise any format above 768 vertical so when I reduced my resolution to 1024 x 768 it worked.
Hope to have helped someone
cheers
Re: Using your TV as PC Monitor
In general most TV's have a lower resolution than most computer monitors.
So you can (with the right converters) easily use a PC monitor to watch TV, but the converse is only realistic with the latest model TV's.
I've got an ANCIENT Phillips computer monitor (from a very early PC and also used on an Atari) which makes an excellent TV when plugged into a VCR or Digibox - it has CVBS and SCART input and even an internal speaker. I suspect it was based on a TV chassis in some way, but has a much better quality tube for PC use.
Fixes: 10
Yes we used to have a Atari monitor too. Rather odd thing it was... couldn't play games on it for some highly annoying reason. Always had to plug it into the TV instead for that. It used to drive me crazy...
