Using xp drivers on a linux o/s
- Re: Using xp drivers on a linux o/s
03-09-2007 1:46 PM
robrow
03-09-2007 4:01 PM
Chilly
03-09-2007 4:04 PM
03-09-2007 4:13 PM
WMWare is great, I run it on my Linux box, and can choose a Windows XP session, at login. (In fact that is how I am typing this message.)
I am also running a HP deskjet 450 USB, on my Windows XP VM, as I had speed issues running it native from Linux, as a shared network printer.
Chilly
03-09-2007 4:17 PM
03-09-2007 10:47 PM
Quote from: chillypenguin What model of printer do you have?
Chilly
Epson R200 Inkjet, it also prints onto cd media
03-09-2007 10:55 PM
Quote from: orbrey Wine is about the only way I could think of, though this is shaky with drivers due to the level of emulation required. As Chilly says, do you have the printer make and model number? It would be a lot easier to install dedicated linux drivers for this to work properly.
The printer is an Epson R200, do you know of any Linux drivers for it including the driver to print on cd media robrow
03-09-2007 11:09 PM
Quote from: chillypenguin Would Wine work? Is that more for running applications.
Chilly
When in an XP session through VM, is your internet connection still through Linux? If so that is perhaps the answer. for both printer and scanner.
03-09-2007 11:34 PM
Needless to say I'm new to Linux, and the response I've had so far from this forum is very encouraging.
Thank you
Robrow
04-09-2007 12:38 AM
See here
04-09-2007 8:15 AM
Quote from: robrow Just realized I have sent replies the wrong way, please excuse me as I'm still learning how to use this Forum.
No problem, I have sorted them for you
04-09-2007 8:20 AM
Quote from: robrow When in an XP session through VM, is your internet connection still through Linux? If so that is perhaps the answer. for both printer and scanner.
Yes, the networking is handled by VMWare, which acts just like another computer on the network.
Chilly
04-09-2007 11:24 AM
Robrow
05-09-2007 10:38 AM
http://tinyurl.com/yphxr8
you'll find a cached Google page of how to install the Epson R200 to Kubuntu. The installation method will (probably) be identical to that of Ubuntu, and will differ very slightly from other Linux distrobutions. You probably wouldn't be able to print onto CD/DVD however.
12-09-2007 2:09 AM
Use CUPS to configure - you can use a web interface for this:-
http://localhost:631/ should do it.
