Using two computers
- Using two computers
Using two computers
17-07-2010 6:21 PM
I have the basic plusnet broadband package. Is it possible to use two computers under the one broadband connection, either at the same time or seperately.
5 REPLIES 5
Re: Using two computers
17-07-2010 6:24 PM
welcome to the forum
I have had four on line at the same time, but each takes it own share, so if one is doing a traffic intensive it might slow the others down
17-07-2010 6:25 PM
Yes
You can connect as many computers as your router will support
Either - 1 on USB and 1 on RJ45
Or - 4 on RJ45
many by wireless
It all depends on the router.
But you can only have one router/modem connected to the line at one time.
If you can advise the router you have we will be able to give more specific guidance
Or - 4 on RJ45
many by wireless
17-07-2010 6:27 PM
it is also possible to have one on your router from home and others at remote locations not using your phone line
17-07-2010 6:32 PM
Thanks for your replies. It is a Thomson wireless router, I think it's the 585v7 and the computers I would use are both wireless laptops.
17-07-2010 6:55 PM
no problem then
