Using a Sky Wireless Booster with Plusnet Router
whitej32
Hi I have just left Sky for plusnet and rather than waste money on a new wireless booster I want to use my old sky wireless booster.
Any ideas how to do this? All I could find on Google was this link: http://www.skyuser.co.uk/forum/wireless-adapters/55261-sky-wireless-booster-other-modem-routers.html
However that was no help Sad
3 REPLIES 3
Marksfish
All Star
Fixes: 5
Re: Using a Sky Wireless Booster with Plusnet Router
I enabled the WPS setting on mine and connected with that. Once connected, I disabled it and it stayed connected.
Mark
whitej32
Quote from: Marksfish
Mark
Thanks for your quick reply Mark.
Sorry how do I enable the WPS setting (I am trying to use the plusnet router with the sky wireless booster rather than keeping my old sky router)?
Thanks again
Jacky
Marksfish
All Star
Fixes: 5
I don't have the PN router connected now, so can't remember where the tick box is to enable WPS. If no- one else can give you the answer, I will find out the router and look it up for you. It is either in the configuration pages or the wireless pages if that helps.
Mark
