Using WiFi for mobile calls
Stranger
Ok, I'm a luddite but my new mobile had the option to use wi-fi when making a call, from my mobile.
Am I okay to do this?
BTW I have broadband and line only, no landline calls package.
17 REPLIES 17
Legend
Fixes: 255
Re: Using WiFi for mobile calls
@Stranger Perfectly OK - if your phone is connected to a Wi-fi network it should default to that anyway - 3/4/5G is only used when you aren't.
Fixes: 419
@Stranger
To clarify what  @jab1  says I believe that it depends on your mobile provider and according to this Plusnet mobile does not support WiFi calling, see. https://www.simsherpa.com/networks/plusnet-mobile/review-and-guide?accept-cookies
Stranger
Thanks John, much appreciated
Stranger
Cheers Baldrick 1, I'm with Tesco mobile, I'll give it a try, if it doesn't work I'm no worse off
Fixes: 419
@Stranger
Sorry, it’s another no go. https://www.simsherpa.com/networks/tesco-mobile/review-and-guide
Stranger
Thanks again
Jmcdc
It only uses your WiFi if its a better connection than your normal phone signals.
According to Google
EE, Vodafone, O2 and Three each offer Wi-Fi Calling in some form, as do some MVNOs (Mobile Virtual Network Operators), but some offer more options or make it available to more phones than others.
https://www.4g.co.uk/news/ee-o2-three-and-vodafone-which-networks-offer-wi-fi-calling/
Mav
Fixes: 515
Moderator's note(s):
Thread moved from ADSL Broadband to Tech Help.
Forum Moderator and Customer
Jmcdc
They who feared to succeed, succeeded in being correct lol
hmarshy
Hello
I have had WiFi Calling with EE for nearly 5 years and basically it has changed my home from a no go zone for mobiles to one where not having a signal is not a problem.
My broadband is provided by Plusnet.
Cheers
Howard
Stranger
Thanks Howard
Strat
Fixes: 565
Some time ago I signed up for an EE deal at Carphone Warehouse which included a Samsung S6.
I had a play with the phone back at home and discovered WiFi calling which I couldn't configure.
I went back to Carphone Warehouse and they explained that the phone had Carphone Warehouse firmware.
In order to use WiFi calling the phone had to have EE firmware.
RobPN
Fixes: 13
Or plain old Samsung firmware?
I'm not an expert on such matters, but perhaps you can re-flash the firmware?
(My SIM free S7 can do WiFi calling)
Jmcdc
That is interesting. I thought they would just be stock. Obviously badly designed software.
