User name change in WIN 7 64bit
- User name change in WIN 7 64bit
24-02-2012 6:10 AM
birdbb2012
Re: User name change in WIN 7 64bit
24-02-2012 6:34 AM
1. Type accounts into the Start menu, then choose the User Accounts link that appears.
2 . Click the option link to change your user name and save the changes.
This will change the name as shown on the login screen (Welcome screen) and the Start Menu. It will not change the folder name, however. This is because the folder is hard-linked to your account in many (hundreds, thousands) of places, and changing the folder name will render your account unusable.
The only way to achieve this is to create a new account, move your files over to that account, then delete the old account:
1. To create a new account go to Control Panel>User Accounts>Add or remove user accounts
2. Create a new account with your name and select Administrator button underneath and select Create Account
Once you have your new account set up as you wish you can delete the old one.
16-08-2012 12:59 PM
Can I assume that all programs I installed (none of them offered the option to install for a specific user) would continue to be available under the new named account and all I would need to do is change any settings to match what I had setup in the old account?
I assume I would have to re-enter all Outlook 2012 email account details (Actually I could just copy/paste (or export/import) the pst file for that.
Forum Moderator and Customer
16-08-2012 2:05 PM
16-08-2012 2:39 PM
It also installs an updater service that runs without any user interaction, kind of like malware really, not good Google.
16-08-2012 5:14 PM
Probably easier to uninstall Chrome then re-install under the new name.
