User forcing updates on Windows 10 Pro N
I run this OS on a VM so the machine's not always on, but when I want to use it I want to get any updates out of the way, is there a way I can force / request an update? Or make changes so it updates as soon as I log in?
2 REPLIES 2
SpendLessTime
Aspiring Hero
Fixes: 86
Re: User forcing updates on Windows 10 Pro N
To request updates, click the search icon on the Windows 10 taskbar, type "windows update" and then click on the "Check For updates" result. Finally click "Check for updates" on the system settings app that started.
@SpendLessTime - Exactly what I was looking for.
